394 crankshaft pulley bolt removal?
Old Nov 2, 2008 | 06:08 AM
sssingo's Avatar
Unhappy 394 crankshaft pulley bolt removal?
Hi there,
Does anyone know if there is a special tool to lock down the crankshaft so you can remove the pulley bolt? What is the correct procedure, as mine is stuck solid.
Some people say use an impact wrench then a hub puller???
Old Nov 2, 2008 | 03:57 PM
68/70 Cutlass's Avatar
Originally Posted by sssingo
Hi there,
An impact should work. A couple times I had to put a brake over bar on it and bumped the starter. You will need a harmonic balancer puller. Don't use any kind of slide hammer tool, you could pull the threads out.
Old Nov 2, 2008 | 07:50 PM
Danny Wiseley's Avatar
The only one I wasn't able to get out using a breaker bar and the starter. . . had to be burned out with a torch. I was amazed it didn't booger the threads.
DW
Old Nov 3, 2008 | 06:06 AM
citcapp's Avatar
I had to crank up the air to 150 FP and use the 3/4" to rattle the last one loose
Old Nov 3, 2008 | 07:24 AM
To get the bolt on the crank snout tight or loose you can get nylon rope and feed it into a cylinder on the compression stroke. Then move the engine over with a wrench and compress the nylon rope against the head. This will prevent the engine from moving. You can then use a breaker bar to break it loose or a torque wrench to tighten it.
Old Nov 3, 2008 | 01:27 PM
sssingo's Avatar
Thanks for the help guys. I shall get on it armed with air impact wrenchs, breaker bars and some rope. Lets hope it works
Old Nov 9, 2008 | 03:47 PM
sssingo's Avatar
all done
thanks again
Mocephus
Apr 12, 2015 06:39 PM
1950 Model Olds
Tech Editor's Desk
Jul 20, 2011 09:02 AM
hawks70
Jun 15, 2011 11:07 AM
D Appeldorn
May 24, 2010 09:21 AM
rustycragars
Dec 3, 2009 10:46 AM
