350 to 455 mounts
Old May 15, 2011 | 09:03 AM
JUMBOJIMBO's Avatar
350 to 455 mounts
69 Cutlass removed the 350 and replacing it with 1974, 455. Got new motor mounts(Engine) does not line up with chasis mounts.Are moving mounts the correct solutoin or am I missing something> Engine has to drop 2 to 3".Rear mount is right on. Thanks ,Jimbo
Old May 15, 2011 | 09:20 AM
507OLDS's Avatar
You can use the 350 engine mounts with the 350 frame pads.
OR you can use the 455 engine mounts,with 455 frame pads.
In your situation,I would use the 350 engine mounts,since you already have the 350 frame pads on the frame.
Old May 15, 2011 | 09:27 AM
https://classicoldsmobile.com/forums...tion-list.html
Old May 15, 2011 | 11:24 AM
JUMBOJIMBO's Avatar
Thanks, Knowledge is a great tool and a real time saver. Jimbo
joesw31
May 31, 2015 04:17 PM
Nasty455
Mar 20, 2012 04:57 PM
flatoz
Mar 15, 2009 02:03 PM
tarps3
Dec 23, 2007 02:10 PM
Steed93
Jun 16, 2006 08:50 AM
