425 wont start
Old May 14, 2011 | 12:29 PM
willj's Avatar
425 wont start
hi ,well i put some gas in and primed it ,it is getting gas to the carb, and is getting fire ,took a few different wires off put spark plug in them , turned over ,and getting spark,you know how you can tell when a engine is trying to start , well it isn,t doing that ,it sounds like it might be trying to fire on one cylinder not popping or back firing ,the engine was rebuilt , carb rebuilt ,all is new ,it is in a 65 starfire, have been working on my baby for three years now ,but this is my favorate car ,so hope someone can help me, thanks to all. will.
Old May 14, 2011 | 01:53 PM
firefrost gold's Avatar
do you have a choke if not you will have to pump the snot out of it small fast shots . check plugs you might have knocked a few out if you poured raw gas in .
Old May 14, 2011 | 06:42 PM
willj's Avatar
got it to run, was off a tooth on the distributor, started right up ,but now it starts but as soon as you let go of key it dies, any opinions, thanks will
Old May 15, 2011 | 12:21 PM
bigoldscruiser's Avatar
2 '66 98's
When holding key to start, ignition is getting 12 volts. When you let go of key, it drops back in voltage via the resistor wire. It sound like you have problems in the resistor wire circuit and losing voltage altogether.
Old May 16, 2011 | 02:51 PM
willj's Avatar
got it to stay going ,it was the carb idle screw was backed off all the way, thanks alot for the help, will
1973_442
Mar 22, 2007 05:42 PM
68oldsrocket
Dec 19, 2006 07:20 PM
monsterpuff
Oct 17, 2006 02:56 AM
monizrage
Aurora
Aug 13, 2006 01:24 PM
J'ville
Jun 10, 2006 03:13 PM
