303 Cylinder Heads
Old Feb 8, 2017 | 05:55 AM
R_CK_R's Avatar
303 Cylinder Heads
Hi,
I'm not sure if I'm in the right Forum here with my 303 but I'll ask anyway
I am rebuilding my Motor at the moment and I want to machine down the cylinder heads.
Now my question: Can you tell me how much can I maximum machine them down to not brake them?
hope you guys understand what I'm trying to tell.
(english is not my native language)
Thanks for any help.
Kai
Old Feb 8, 2017 | 06:18 AM
Tedd Thompson's Avatar
What are you trying to achieve, higher compression, remove rust or corrosion, warped head ? First generation Oldsmobile heads are quite thick but every head has it limits and is a individual to it self. Keep in mind that when you change head dimensions radically valve geometry also changes and push rods or rocker stems will need to be adjusted accordingly if a large bite is taken off..... Tedd
PS. You would probably be better putting this and other posts related to first generation Oldsmobile's in the vintage forum where the early Olds guys hang out.
Old Feb 8, 2017 | 06:26 AM
R_CK_R's Avatar
Hi Tedd,
Thanks for your fast reply.
I want to get the area straight and flat to have to heads sit clean on the block.
If I can achieve a Little more power with higher comporession it would be nice.
I don't want to change anything radically, just a little bit.
Kai
Old Feb 8, 2017 | 07:00 AM
You should have no problem by having your machine shop just clean up the heads in a normal way. Shaving the heads by itself won't give you a lot more power, incorporated in a complete build it would help but you will need deep pockets to make a racer out of a 303, it can be done.... If you have the time this thread from the HAMB will give you a lifetime of information... Tedd http://www.jalopyjournal.com/forum/t.../#post-1661960
Old Feb 8, 2017 | 10:15 PM
R_CK_R's Avatar
Hi Tedd,
thank you very much.
I'll look this thread up today.
1956olds
Jun 2, 2009 09:16 AM
Nailhead 88
Jul 29, 2008 11:46 AM
ricardo
Jan 27, 2008 11:27 AM
oldcutlass71
Dec 1, 2007 03:21 PM
Swed Olds
Nov 18, 2007 04:51 PM
