262/268 cam idle
262/268 cam idle
Hello,
I have a 455 with a voodoo 262/268 camshaft. I really like the low and mid range, but the idle is rougher than I like.
Timing is 35 total + 12 vacuum (manifold). Stock quadrajet, about 17in Hg of vacuum at idle. There are times when the idle is fairly rough and others when it smooths out. Something is inconsistent and I'm not sure what it is. Richer idle seems to help (seems to run best at around 12:1, but I'd rather not run that rich). Any ideas how I can smooth it out?
Thanks.
Thanks.
Try an advance curve kit. I assume it is running low base timing like a points ignition? If you don't want to run more vacuum advance, recurve so there is less mechanical advance and more initial timing at idle.
My problem is that it makes the car shake, which is annoying. I have an old truck with a Cummins 4BT (engine known to be very uncivilized) and it is silky smooth in comparison.
You get used to it.
The strange thing is that it is inconsistent. I want to find the conditions under which it doesn't do that and replicate them.
Perform a cylinder balance test while the rough idle is occurring.
How about take a timing light and hook it to each spark plug wire while it's running rough. Point the light at the underside of the hood and look for consistent flashing without any stuttering. Do that for all the plugs. If any stutter than it could be an ignition problem. If you don't see any stuttering (missed flashes) then at least you know it's not due to an ignition problem.
The primary shaft in my quadrajet had quite a bit of play. I addressed that and I saw a great improvement. It likes to idle at around 13:1 A/F (a bit rich for my taste, and might hint to other vacuum leaks), but it is quite acceptable now.
I’m gonna suggest that unless your Qjet is modified (idle air bleeds, etc) and optimized, you’ll have trouble getting the idle consistent, even with a relatively small cam like that. If there are no vac leaks presenting themselves, my guess is that it’s internal calibration. That cam is still way bigger than what that carb was calibrated for.
Doug Roe, Cliff Ruggles and Ken Gies (occasionally on this site as “techg8”) all have books available if you feel up to the task of modifying.
