1972 455 (4bbl) - fuel pump inlet & return?
Old Jul 8, 2023 | 02:05 PM
jpilk99's Avatar
I bought my '72 Olds 98 with 455 4-bbl a few months ago. Much "fixing" has been done, and I'm getting ready to install & connect my new gas tank. I already ran new fuel lines from the front to the back, matching the lines that were already there. NOTE: When I got the car, there were 2 rubber fuel lines connected to the fuel pump and both lines were about 3 feet long that sat in a little 1-gallon portable gas tank sitting up by the passenger headlight, next to radiator.
I can't tell which is the Inlet side of the fuel pump and which is the return. I figure I can pull off the rubber hoses - which I trimmed down to about 4 inches to slide over the ends of my new metal fuel line(s).... But just thought I'd ask. I checked the CSM and didn't find where it specified. I assumed, that one rubber fuel line would have larger diameter than other, but I think the guy I bought it from just slapped the same diameter hose on both the inlet and outlet(return) ports of the pump.
Old Jul 8, 2023 | 02:16 PM
jpilk99's Avatar
And I'm still an idiot. Just took off both hoses to reveal the answer. Sorry y'all. I shoulda been more thorough.
Old Jul 8, 2023 | 02:38 PM
The 3/8" hose is inlet from the tank to the pump. The 1/4" line is the return from the pump to the tank.
Old Jul 8, 2023 | 04:03 PM
jpilk99's Avatar
thanks Joe
Old Jul 9, 2023 | 08:33 AM
cfair's Avatar
You might not have room there, but if you can insert a fuel filter between the tank and fuel pump, it may keep your engine running better.
Also put enough slack (length) in the rubber hoses to allow them to move a little, but not so much that they interfere with the belts.
Old Jul 9, 2023 | 09:30 AM
jpilk99's Avatar
Good call, thanks!!!!
allyolds68
Jan 4, 2024 09:49 AM
johnnyjaws
Nov 30, 2014 06:12 AM
69 holiday
Jan 9, 2014 09:30 AM
Joah_from_Alberta
Oct 1, 2013 03:36 PM
mryoung4815
Jun 23, 2010 05:35 PM
