1971 water valve
Old Sep 26, 2015 | 07:49 PM
Microreedy's Avatar
1971 water valve
I have a 1971 442 and the water valve does not have a vacuum port on it. Car has ac. Is this correct for some applications? If so how do you route the vacuum hoses?
Old Sep 27, 2015 | 06:07 AM
The water valve must have a vacuum port to operate. Either yours is broken or incorrect. Also note that the 1972-earlier A-body cars use a valve that is normally closed and opens with vacuum applied. The full size cars used a valve that is normally open and closes with vacuum. Be sure you get the correct one for your application.
jensenracing77
Mar 19, 2014 04:08 PM
oldspackrat
Apr 20, 2011 07:08 PM
1973olds98
Dec 15, 2010 04:39 PM
rhett838
Aug 25, 2010 07:01 PM
bullet1
Sep 3, 2009 05:43 AM
