1971 455 cu in A Body SM
Old Nov 29, 2025 | 07:37 AM
oldJW's Avatar
So.. I'm in the Chassis Service Manual reviewing the crankcase ventilation diagrams. What is the 'SM' in 455 cu in A Body SM?
Old Nov 29, 2025 | 07:51 AM
oldoldss's Avatar
https://classicoldsmobile.com/forums...estion-168736/
It applies to a car with a Manual Transmission.
Old Nov 29, 2025 | 07:55 AM
oldJW's Avatar
Very well. Thanks very much.
Old Nov 29, 2025 | 07:00 PM
That's because big block cars with manual trans got the same dual ventilation PCV system as did the W30 cars. The PCV valve goes to a barb on the intake manifold behind the t-stat and both valve covers have breathers that connect to the air cleaner. Note that the cast iron BBO intakes for 1970-72 have a boss cast behind the t-stat. For MT (aka SM) applications, that boss was drilled and a hose barb was pressed in for the PCV. The basic casting number is the same in both cases, which has led to a lot of confusion on the part of people who think that they have a "rare" cast iron MT intake, but it doesn't have the hose barb.
Old Nov 30, 2025 | 04:23 PM
oldJW's Avatar
Thanks, Joe.
I had seen a similar post where you explained this (slightly different set of pics), but I didn't know that SMT, MT, and SM were all interchangeable. I recently purchased a car not running and driving... with some disassembly as well (and parts missing). Trying to put it all back together correctly; glad to have the experts keep me focused on the correct diagrams.
JW
Pekarrr
Oct 2, 2019 12:22 PM
70sx455
Jun 25, 2014 10:51 AM
costpenn
Feb 3, 2012 12:37 PM
DennisG.
Feb 12, 2011 12:57 PM
