1970 Delta 88 455 4 barrel - thoughts on engine swap
Old Jun 27, 2024 | 02:04 PM
72cutlass408's Avatar
Is this a good option to put in a 69’ Cutlass 4 speed? It’s in a running car with 80k on it, he’s asking $1k. What do you guys think? What should I look for?
Old Jun 27, 2024 | 02:42 PM
You'll have pilot bearing issues to overcome because it came from an automatic trans car. Make sure it has the zbar boss on it.
Old Jun 27, 2024 | 03:59 PM
Thanks I forgot about the z bar….it’s been awhile
Old Jun 28, 2024 | 03:45 AM
If it's a running car is the seller going to remove the engine for you? Is that price oil pan to air cleaner, and fan to flywheel?
Old Jun 28, 2024 | 08:22 AM
Yes, running car from air cleaner to oil pan and he’s pulling it.
Old Jun 28, 2024 | 10:30 AM
Cosmic Charlie's Avatar
my 69 cutlass vert fake 442 has:
a 70 455 from a full size
a 69 M20
a .308 converted to posi
car is a great driver
Old Jun 28, 2024 | 05:26 PM
@11971four4two has (or had) a BBO crank drilled for pilot bearing, I think. May still be available.
Old Jun 28, 2024 | 06:11 PM
2blu442's Avatar
I've got crankshafts drilled for the manual transmission up in Oregon. But if your hope is to run the engine without rebuilding it you may not want to swap out the crankshaft. John
Old Jun 28, 2024 | 06:26 PM
64Rocket's Avatar
Manual trans crank
Give me a call. I’m in Union city/Fremont
5104999235
NiceOld(s)Car
Jun 6, 2024 04:21 AM
Grimmlock
Feb 13, 2023 05:17 PM
eric66
Cars Wanted
Aug 2, 2016 06:00 PM
mahoneybags21
Mar 11, 2009 10:16 PM
mahoneybags21
Mar 11, 2009 04:22 PM
