1969 Delta 88 455 needs new carb, can’t find a Quadrajet
Does anyone know where to get a Quadrajet rebuild? I can’t find one available any time soon. Or can you recommend a good after market that isn’t a pain to install? The housing on mine is stripped and possibly the fuel inlet.
The stripped fuel inlet is common and easily fixed with a heli-coil. Your 1969 uses a 7029251 carb, which is one of the most common Oldsmobile Qjets out there. I would not recommend a commercial rebuilt carb, since most are frankencarbs.
I've gotten two from there and both have worked well. One for a 73 455 and one for a 71 Chevy 350 c20 truck. Both were numbers correct for the application. Not show quality with the epoxy plug on the front, but very good performance wise with supposed correct factory jetting and metering rods. I would call with the original part number though, since the website doesn't list all available parts.
Hooptie
Apr 19, 2017 09:19 AM
