1969 Delta 88 455 needs new carb, can’t find a Quadrajet
Old Oct 2, 2023 | 05:43 PM
RichieD's Avatar
Does anyone know where to get a Quadrajet rebuild? I can’t find one available any time soon. Or can you recommend a good after market that isn’t a pain to install? The housing on mine is stripped and possibly the fuel inlet.
Old Oct 2, 2023 | 05:49 PM
Ray Kleem on Facebook builds them, he has lots of cores.
QuadraJet power also builds them. I’m sure there are many more
Old Oct 2, 2023 | 07:34 PM
Sugar Bear's Avatar
National Carburetor in Jacksonville FL is worth a call or email. They did nice work on a different brand for us about a year ago and turned it around in a little over a week with shipping.
Old Oct 2, 2023 | 11:09 PM
cfair's Avatar
I get mine from SMI (Sean Murphy Induction) in SoCal. Have for 10 years or more. Stock-ish with a slight bent toward performance
Chris
Old Oct 3, 2023 | 01:58 AM
The stripped fuel inlet is common and easily fixed with a heli-coil. Your 1969 uses a 7029251 carb, which is one of the most common Oldsmobile Qjets out there. I would not recommend a commercial rebuilt carb, since most are frankencarbs.
Old Oct 3, 2023 | 02:06 AM
rickw30's Avatar
John Herald (843-408-7416) most likely has that one in stock. Located in NC. He can rebuild yours and fix that fuel inlet.
Old Oct 3, 2023 | 03:34 AM
You can fix the threads with a self tapping fuel inlet too. Like Joe mentioned though, the proper way to fix the carburetor is to heli-coil the fuel bowl.
Old Oct 3, 2023 | 05:19 AM
Oldsguy's Avatar
Past Administrator
I think I read on the site someone selling two Qjet cores. Might be worth a search.
Old Oct 3, 2023 | 09:48 AM
^^x2^^
Very common fix you can easily perform yourself.
Old Oct 3, 2023 | 10:30 AM
@rickw30
... later 800 CFM carbs though. Not correct for OP's application.
Old Oct 3, 2023 | 05:22 PM
LettuceHead's Avatar
Guaranteed Carburetors in Tampa Florida is very good, pretty sure they ship too.
Old Oct 4, 2023 | 09:33 PM
Donaldbabineau's Avatar
I've gotten two from there and both have worked well. One for a 73 455 and one for a 71 Chevy 350 c20 truck. Both were numbers correct for the application. Not show quality with the epoxy plug on the front, but very good performance wise with supposed correct factory jetting and metering rods. I would call with the original part number though, since the website doesn't list all available parts.
Old Oct 5, 2023 | 08:16 AM
Burd's Avatar
Cliff Ruggles in ohio, the Best!
Old Oct 5, 2023 | 08:22 AM
rickw30's Avatar
Cliff retired from rebuilding.
He only sells parts now.
otto72
Cars Wanted
Nov 24, 2022 06:42 AM
Hooptie
Apr 19, 2017 09:19 AM
agreen316
Jun 11, 2014 10:22 AM
D Appeldorn
Dec 13, 2011 11:28 PM
D Appeldorn
Mar 6, 2011 09:36 AM
