1968 400 w-30 engine question
Old January 29th, 2013, 04:16 AM
  #41
allyolds68's Avatar
Originally Posted by Bernhard
I don't know why there is so much negative posts on this engine. ........so easy it spun rod bearings.
You just answered your own question. Every person I've known that owned one of these cars in the 60's and early seventies had the same thing happen (although a lot of people spun mains). My next door neighbor owned a 69 W30. He sold it and the kid that bought it had it blown up in a week. One missed shift.
allyolds68 is offline
Old January 29th, 2013, 06:32 AM
  #42
Motorhead
jcosta77's Avatar
Motorhead
Our 400 G block was .060 over and had great TQ and spun up real quick, I always felt it was a good engine. It might not make as much hp/tq as a 455 but it is 55cu less. I don't know why there is so much negative posts on this engine. Same heads,crank,rods as a 455. The engine pulled hard through a 1/4 mile and spun past 5500rpm with easy ,so easy it spun rod bearings.I know every one posts that the valve's are shrouded but they got them to run in the 12's in stock eliminator back in 69. When stock was stock in the glory days before the fall of the class.
The reason that you spun the rod bearing was from lack of oil. These engines used a very high volume pump which would suck the pan dry at extended high RPMs. You have to open up the drain passages to get the oil to return faster to the pan and reduce the flow of oil to the rockers (you can purchase restricted push rods and cam bushing to assist). Also notching the sides of the con-rods helps to allow the oil to escape. Doing this will eliminate the starvation of oil in the pan during high RPM operation.
These engines will produce high hp/torque, great for the street and keeping your car original.
I will be switching to a lower highrise intake so I can run the original air cleaner in a couple of weeks, will let you know the dyno results at that time.
jcosta77 is offline
Old January 30th, 2013, 11:52 PM
  #43
Bernhard's Avatar
This was a big block problem not just a 400 big block problem.
I always felt that our 400 spun up quicker than 455 that we had.
I'm looking at a 69 442 on the weekend with the a original 400 engine. If I buy it I will take it to the track in the summer and see what it will do after some tuning.
Bernhard is offline
Old January 31st, 2013, 12:30 AM
  #44
Bernhard's Avatar
Have you read BTR's engine building book? I just got a copy today its a good read.
Look forward to your dyno results and track times
Bernhard is offline
Old January 31st, 2013, 10:41 AM
  #45
Bernhard's Avatar
What pistons are you using in your 4.00 inch bore 400 G block, custom or other ?
Bernhard is offline
Old January 31st, 2013, 05:53 PM
  #46
Motorhead
jcosta77's Avatar
Diamond pistons, and I should be putting it back on the dyno next week, will let you know. Won't be going into the car until May or June when the body is completed.
jcosta77 is offline
Old January 31st, 2013, 06:02 PM
  #47
Motorhead
jcosta77's Avatar
Let me know what BTR's theory is in regards to the 400-455 spinning bearings?
and also if they mention the amount that the 400 can be bored out to safely?
jcosta77 is offline
Old January 31st, 2013, 06:53 PM
  #48
Bernhard's Avatar
For the engine not to spin bearings clearance must be larger than stock. Factory block,crank are weak and heavy pistons and rods + rods are soft. As engine rpm goes up the block flexes the crank flexes and the rods stretches. You end up with no oil between the rod bearing and crank or main bearings and crank. You have metal to metal contact. So to compensate for this flex,stretch,movement you need larger clearances.
This is my interpretation of what I read in the book.
I would get the book and give it a read and make your own interpretation!
The next engine I build will be with the guidance of this book
When Bill talks about weak he is talking HP engine builds not factory stock engines that stay with in normal rpm range.
Bernhard is offline
Old January 31st, 2013, 07:19 PM
  #49
Motorhead
jcosta77's Avatar
Makes sense, I will let you know how my engine works.
jcosta77 is offline
Old February 19th, 2013, 12:07 PM
  #50
Motorhead
jcosta77's Avatar
Had the engine on the dyno on Friday and it pulled 455hp and just over 500 ftlbs of torque. strong pulls and oil pressure stayed in the mid 40 psi range.
Will post video and dyno spec sheets soon.
jcosta77 is offline
Old February 19th, 2013, 09:11 PM
  #51
Bernhard's Avatar
Very nice numbers for any Olds build.
Bernhard is offline
Old February 20th, 2013, 04:27 AM
  #52
allyolds68's Avatar
Those are great numbers. I guess there is hope for that block I have sitting in a dark corner.
You should start another thread with the build details and dyno results.
Mr_Ada
October 24th, 2014 11:58 AM
Draven
January 19th, 2012 08:37 AM
Gearhead442
January 27th, 2011 03:03 AM
sbFALL63
January 23rd, 2011 09:01 AM
sbFALL63
May 28th, 2010 05:45 AM
Quick Reply: 1968 400 w-30 engine question
