1967 442 air cleaner issue
Old Aug 19, 2022 | 11:35 AM
Bills67's Avatar
I have a clearance issue with my air cleaner! I installed a Edelbrock performer RPM intake manifold and a Holley Super Sniper 4150 EFI carb! I measured from the top of carb to top of fenders and I only have about 2 1/8" to 2/14" more like 2' of clearance. has anyone installed this same set up and if so what air cleaner did you use or what are, if any, my options?
Old Aug 19, 2022 | 08:38 PM
66SportCoupe's Avatar
The problem with anything Edelbrock is the throttle arms are too high. Hang up on the air cleaners. Especially drop based ones.
Old Aug 27, 2022 | 10:25 AM
Bills67's Avatar
I believe I have solved my issue with air cleaner clearance on my car with Holley 4150 EFI and Edelbrock performer RPM intake! I bought a drop base and a 1/2" spacer and it seems to have enough clearance now. I needed the spacer because the drop base would not fit with out it. The true test will come when I install the hood!
Old Aug 28, 2022 | 06:58 AM
I'm using one of these on my car with a Holley carb.
1964-1972 Chevelle Open Element Air Cleaner Kit (ss396.com)
Old Aug 30, 2022 | 09:25 AM
oletrux's Avatar
Looks to me like your straight edge is showing the top of your hood, not the underside.
Old Aug 30, 2022 | 12:15 PM
Yeah ... better hope your engine is balanced and the mounts are in good shape, because it looks like it's gonna be pretty tight to me.
Old Aug 30, 2022 | 12:23 PM
I got a hood for you to make a shaker out of.
Old Aug 30, 2022 | 01:01 PM
Bills67's Avatar
yea I know! I am hoping that the hood has a little crown for some more clearance. i have not put the hood on yet because I have some more work to do, but when I do I will lower slowly and put some clay on top so I can see just how much room I have, if any.
Old Aug 30, 2022 | 01:07 PM
Bills67's Avatar
is it a 442 hood or Cutlass? got any pics and how much and where are you located? I am in Northern Mi (Cadillac)
Old Aug 30, 2022 | 01:13 PM
Bills67's Avatar
The engine is balanced but I might have to weld some straps onto the mount or put a cable from engine to frame like I did on my 65 Stang but I will wait to see after I put my hood back on!
Old Aug 30, 2022 | 01:20 PM
Bills67's Avatar
Holley EFI Sniper? I like that cleaner! looks like I could use my decal from original cleaner on it, but it looks like a 3" cleaner to me and mine is 2" now and my drop base works on a Holley 4150 but not on the EFI carb with out 1/2" spacer.!
Old Aug 30, 2022 | 08:03 PM
442Dude's Avatar
I wonder if any of my tips or tricks from what I did on my 71 will help? Here's the link to what worked for me.
https://classicoldsmobile.com/forums...sniper-162811/
Old Sep 4, 2022 | 10:43 PM
I've got a spare 442 hood I am keeping, and I have this Cutlass hood I could sell. Problem is getting it to you as I am in lower Indiana. I'd sell the Cutlass hood for 100, but, again, the shipping is the issue and so is the time packaging it and getting to the freight.
Old Sep 5, 2022 | 05:18 PM
Bills67's Avatar
can you send me some pics of the hood? how far from Cadillac MI. are you?
coppertopgmc
May 28, 2020 08:23 AM
67w30
Jun 2, 2017 06:28 AM
Gerald Nickels
Nov 26, 2016 07:45 PM
tecar442
Jul 20, 2013 08:53 AM
wj67442
Feb 15, 2007 03:54 AM
