1965 425 oil drain plug
Old Nov 21, 2016 | 07:21 PM
tgcom's Avatar
Looking for a replacement for my torx drain plug, mine is pretty beat up . Is there a new replacement or a source for a good used one? Thanks, Tom
Old Nov 21, 2016 | 08:47 PM
steverw's Avatar
I have no idea but perhaps you could weld a bolt head or a cut off socket to your old one?
Old Nov 22, 2016 | 05:34 AM
Have you looked in the Help section at your local auto parts store? If they don't have anything you can buy something like this based on the thread size and pitch:
https://www.summitracing.com/parts/sum-g15
The only bad thing is that the new bolt probably won't be a Torx bolt. Then again, I didn't think Torx was used on any classic Oldsmobiles...
Old Nov 22, 2016 | 06:02 AM
Torx fasteners were not used in 1965. That's an eight point drive, Torx has six. The drain plug is really just two 1/2" square drive recesses overlapping by 45 degrees. You can remove it with a 1/2" square drive ratchet and no socket. Threads are pretty common. Just match them up with other drain plugs.
Old Nov 22, 2016 | 11:49 AM
m371961's Avatar
Oh, the simple days. Pain in the but with all the different sockets needed now.
Old Nov 22, 2016 | 06:21 PM
tgcom's Avatar
Thanks for replies. I can still engage the plug with a 1/2 drive but just barely. Might try to weld on a hex as suggested, haven't been able to find a new 7/8-20 thread ( I think thats the size) drain plug.
Old Nov 22, 2016 | 06:22 PM
edzolz's Avatar
Not so, the thread is something like 7/8-20. I tried to find threaded rod this size to make one but finally found a stock one that I bought one from another CO member. I would have to cut special thread on bar stock to make one.
Ed
Old Nov 22, 2016 | 06:43 PM
edzolz's Avatar
tgcom -- you have a PM
Old Nov 23, 2016 | 05:11 PM
Charlie Jones's Avatar
Phantom Phixer
The GM part number for this drain plug is 577646 .
I googled the number and came up with this lead . You will have to call them to make sure they have it and get a price .
http://www.phillipsmusclecarpartsinv...rt-number.html
Old Nov 25, 2016 | 06:38 AM
edzolz's Avatar
Looked at the old one I have and the threads are pulled and it is not usable. I remember that is why I needed another one.
Old Dec 14, 2016 | 10:29 PM
Gerald Nickels's Avatar
plug
I just found one a week ago now where did I set it down at. This is no lie. If I find it i'll reply
Gerald
Johnny HR
Apr 23, 2013 12:44 PM
tpawlik
May 8, 2011 08:19 PM
Dan Wirth
Oct 18, 2009 07:27 PM
Olds64
Feb 17, 2009 01:20 PM
prawnman88
Apr 27, 2007 07:54 PM
