1964 394 Engine Compression PSI??
Old Jun 5, 2018 | 05:25 AM
BillJack's Avatar
I have a '64 Olds 394 Starfire engine, 345 hp. What lbs/square inch (PSI) should I see when I do a compression test? Results taken last evening are as follows: cylinder 1-180 psi, 3-185, 5-182, 7-168, 2-180,4-161, 6-189, 8-166. Thanks for you help!!
Old Jun 5, 2018 | 09:58 AM
Don R.'s Avatar
When I got my 63 six years ago the engine was said to be rebuilt with about 3000 miles on it. I did a dry compression test and got 180 to 182 psi all around which I was very happy with. Your numbers look good to me.
Old Jun 5, 2018 | 11:16 AM
BillJack's Avatar
Thanks Don for taking the time to relay that info to me! Much appreciated. I suppose then that my engine is in decent shape. I still need to do a carb rebuild and repair the exhaust leak. Thanks again!
Old Jun 6, 2018 | 03:59 AM
BillJack's Avatar
I looked in an old "Motors Manual 1966" that I have. It says the 394 compression is 190 psi. So I'm a little low on seven of the eight cylinders. I did not test with ALL plugs removed. I tested with only one plug removed at a time. I will retest to determine if this will make a difference.
Old Jun 6, 2018 | 07:44 AM
Don R.'s Avatar
That will make a difference, don't know which way. My test was with all plugs out and carb wide open, but the engine was cold, ideally it should be hot.
Old Jun 6, 2018 | 08:36 AM
OLDSter Ralph's Avatar
You're probably good enough. There might be a range that's acceptable like 170 to 190. This is a dry test ?
Old Jun 6, 2018 | 10:00 AM
B964's Avatar
Should be an acceptable PSI range and a percentage difference value. If acceptable was say between 160 to 180 you still wouldn't want seven at 178 and one at 161.
Old Jun 7, 2018 | 01:50 AM
Ozzie's Avatar
The 1964 Oldsmobile Service Manual (number 1) page 5-3 says to open choke & throttle, remove all spark plugs, and be sure battery is charged. The lowest cylinder should not be less than 80% of the highest, and no cylinder should be less than 100 PSI. A bit of oil can be added to the cylinder to check for ring problems.
Old Jun 7, 2018 | 03:58 AM
BillJack, you can't get any better than from Oldsmobile. I was using 10% variance off the top of my head. Recheck compression PSI and let us know.
INTRUDER
Dec 19, 2019 01:36 PM
Duneracer
Jun 12, 2017 04:31 PM
dennis_30281
Mar 8, 2017 07:37 AM
WaynesWorld
Dec 11, 2010 08:38 AM
chipowpow
Dec 8, 2010 05:35 AM
