1962 Delta 88 poor start, flooding every crank?
I made a post awhile back about poor starting. Haven't gotten anywhere to fixing it yet, but did some diagnosis and noticed this very not normal spewing of gas into the carb. Seems like I'm flooding it with every crank, is this just a stuck choke or what? I'll be taking it in for a check by a mechanic who knows what to do, but was hoping someone might be able to point me in the right direction in case there is a DIY fix or in case there's just more I should know.
Youtube video showing the issue better than I describe it.
Ask the mechanic first but they might want you to source a new float and carb rebuild kit before taking to the garage. Your going to need it anyway.
Curious, was the fuel pump replaced recently? I've read about the pressure being too high on new pumps and a pressure regulator added to the line works around the issue.
Good luck!!!
Good luck!!!
Good luck!!!
Good luck!!!
Be careful running it, that could be a fire hazard.
Sometime it is dirt between the needle valve and seat, a bad needle valve, a heavy float, or a seat that loosened in the carb body. I've had success flushing a dirty needle and seat by pinching the rubber hose to the fuel pump closed and letting the carb run dry. When restarting with the empty fuel bowl the volume and surging of the inbound fuel from the pump flushes the needle and seat clear. Dirt/debris on the needle and seat wasn't all that uncommon immediately after replacing a fuel filter.
Good luck!!!
Good luck!!!
Good luck!!!
Good luck!!!
Any one have a recommendation on a good kit specifically for Oldsmobile carb kits.
Is the car a '62 or '72?
A carb rebuild isn't difficult as long as your work methodically, clean and follow a manual explicitly.
One risky part is stripping or cross-threading the threads at the fuel inlet nut. Be super careful with those threads. The float, needle valve and seat could be done on the car without a full disassembly but I'd pull it all apart for a cleaning.
Good luck!!!
Good luck!!!
Good luck!!!
Good luck!!!
Interesting, I ordered the rebuild kit and a float. Then opened it up this afternoon because I had some spare time (3 kids, oldest is 5 spare time is hard to find). Tested the float in some hot water, zero bubbles. And from the look of the gaskets this carb was rebuilt recently so I reassembled and it's never started so easily. I'm guessing something in there was sticky, cross fingers to see if it keeps working.
Also cracked a dry rotted vacuum hose in the process, so off to the store to find a replacement for that.
synoptic12
August 19th, 2020 08:51 AM
HurstLightning84
July 25th, 2017 05:50 AM
