Scanner
Old Jun 11, 2026 | 03:15 PM
70-455's Avatar
Scanner
Anyone know what scanner i can use for a 95 aurora.The hand held ones aren`t compatible with that car.
Old Jun 12, 2026 | 04:58 AM
Your Aurora is probably OBD 1.5. 96 was the first full year for OBD2. I used an Innova 3160 for the 96 98 I owned. It was the second best car I've ever driven behind @Oldsguy 76 98 he had when I was younger.
Innova 3160
You need to look at your Assembly Line Data Link under the dash. Is it GM Type 1 (top) or OBD2 (bottom)?
BTW, any auto parts store should be able to scan the codes your car might have stored. Plus, if it's isn't OBD2 all you need to check the codes is a paperclip.
Old Jun 12, 2026 | 05:03 AM
66_Jetstar's Avatar
I would look into an old snap on mt2500. Should be dirt cheap used and will have lots of capability.
Old Jun 12, 2026 | 11:09 AM
pizza442's Avatar
I remember dealing with my 95 Aurora. Tech buddy at the dealership said they had the newer-style OBDII plug but was still OBDI so he needed to use some kind of adapter to hook up his Tech2 scanner...interestingly, I'm just now hearing this being called OBD1.5. I wonder how many other GM models in '95 were like this? Cadillac?
Old Yesterday | 08:45 AM
70-455's Avatar
Scanner
I have the 16 hole plug.With only 8 pins showing.
Old Yesterday | 09:52 AM
pizza442's Avatar
Here is possibly what you need, I think, but not 100% sure. Maybe someone more informed can confirm:
www.ebay.com/itm/800115200345
Or:
Old Yesterday | 10:39 AM
No, he doesn't need a GM Type 1 to OBD 2 adapter. You just need an OBD2 scanner. Like the Innova scanner I used for my 96 98. Here's the OBD 2 port.
Old Yesterday | 12:56 PM
pizza442's Avatar
Is buying another scanner his only option? Wouldn't this inexpensive adapter work if he already has access to an older code reader?
Old Yesterday | 01:36 PM
66_Jetstar's Avatar
The problem is his code reader doesn't have the pre-OBDII software. It won't know what to do. This would be like plugging in your xbox controller into a Playstation.
Old Yesterday | 05:35 PM
There's no need to use a GM Type 1 scanner. You can pull codes from those cars with a paperclip. The computer is pretty primitive.
If the OP doesn't want to buy a $200; scanner he can always get the codes read at an auto parts store.
Old Yesterday | 07:52 PM
70-455's Avatar
scanner
The Inova 3120 scanner I bought off eBay. I was told it had the program my 92. Toronado had the same problem it wouldn’t read and when I called Inova come to find out it’s not program for the Torado or for the aurora I’ll have to look into the 3160 Innova thanks for all the information guys
78Cutlass4Speed
Jan 27, 2026 08:16 AM
dandunham
Intrigue
Jun 26, 2024 09:44 AM
RXN
May 14, 2013 03:28 PM
Axeni
Feb 22, 2012 06:24 AM
Tedd Thompson
Sep 24, 2010 07:13 PM
