Oil pressure sensor location on Aurora 4.0
Old Dec 4, 2020 | 06:20 PM
jamesx123x's Avatar
I've got a low oil pressure warning on the DIC earlier when I started the engine, I turned it off. It disappeared when I started the engine again, the rpm meter went down to .5 then it revs to 2.
I stepped on the brake pedal for a full stop, then it moves faster than normal when I let go of the brake pedal.
I researched the cause of it already and I found that the oil pressure sensor is broken or malfunctioning but I could not find where it is located.
Any help would be appreciated sirs.
Old Dec 5, 2020 | 11:11 AM
DJS70cutlass's Avatar
On that one it's threaded into the oil filter housing. Just above the filter, connector points to the drivers side.
Old Dec 5, 2020 | 06:08 PM
jamesx123x's Avatar
Thanks DJS70cutlass.
Something came up, I thought I'm just dealing with a low oil pressure issue, now my car won't start. When I turned the ignition key, it's making a sound, so I'm assuming it cranking, and the battery was just replaced a couple of months ago. I don't know what's going on now.
Human
Aurora
Oct 29, 2016 04:58 PM
69CutlassAlex
Oct 24, 2011 04:55 PM
Thomas Simcich
Oct 13, 2010 11:28 AM
442 Guatemala
Jan 27, 2009 10:12 PM
airhead6969
Aug 10, 2006 11:00 AM
