Oil pressure sensor location on Aurora 4.0
I've got a low oil pressure warning on the DIC earlier when I started the engine, I turned it off. It disappeared when I started the engine again, the rpm meter went down to .5 then it revs to 2.
I stepped on the brake pedal for a full stop, then it moves faster than normal when I let go of the brake pedal.
I researched the cause of it already and I found that the oil pressure sensor is broken or malfunctioning but I could not find where it is located.
Any help would be appreciated sirs.
Thanks DJS70cutlass.
Something came up, I thought I'm just dealing with a low oil pressure issue, now my car won't start. When I turned the ignition key, it's making a sound, so I'm assuming it cranking, and the battery was just replaced a couple of months ago. I don't know what's going on now.
