1996 transmission issue
Problem: When engine is cold transmission will shift and will be able to drive it for about a mile or so. When engine gets hot trans just seems to shut down. If I turn the engine off for 5 to 10 mins can drive it a little further. What causes this? Help
Boylost
Boylost
seals going
A lot of times that is caused form the tranny pump going it gets hot the seals bleed by and does not create enough pressure to operate the tranny.
pull the dip stick and smell the fluid it may be just a burnt tranny.
Good luck
Good luck
aurora transmisson issue
Thank you for your feedback! I have looked at the trans fluid all appears to be fine and clear. Not burnt or brown. Where is the trans pump. I got under the car but its all a blur to me...
I want to do it. But I think you are right the trans is getting hot...
ricardo
Drivetrain/Differentials
March 16th, 2008 07:04 PM
