1996 transmission issue
Old Aug 28, 2006 | 09:32 AM
boylost's Avatar
Problem: When engine is cold transmission will shift and will be able to drive it for about a mile or so. When engine gets hot trans just seems to shut down. If I turn the engine off for 5 to 10 mins can drive it a little further. What causes this? Help
Boylost
Old Aug 28, 2006 | 02:58 PM
ndiver63's Avatar
seals going
A lot of times that is caused form the tranny pump going it gets hot the seals bleed by and does not create enough pressure to operate the tranny.
pull the dip stick and smell the fluid it may be just a burnt tranny.
Good luck
Old Aug 28, 2006 | 03:16 PM
boylost's Avatar
aurora transmisson issue
Thank you for your feedback! I have looked at the trans fluid all appears to be fine and clear. Not burnt or brown. Where is the trans pump. I got under the car but its all a blur to me...
I want to do it. But I think you are right the trans is getting hot...
Old Aug 28, 2006 | 03:34 PM
ndiver63's Avatar
Trans pump
it is located inside the tranny behind the torqu converter. Not something you can do unless you know how to rebuild trannys
Old Aug 29, 2006 | 06:46 AM
boylost's Avatar
1996 aurora transmission
So the pump is inside the transmission... How big a job is that and what would be your estimate of cost?
ricardo
Drivetrain/Differentials
Mar 16, 2008 07:04 PM
goofman156
Nov 8, 2007 04:55 PM
tobz
Apr 3, 2007 10:09 AM
BillR
Cars Wanted
Dec 2, 2006 01:24 PM
monizrage
Aurora
Aug 13, 2006 01:24 PM
