Warning lights
Old Mar 1, 2012 | 09:59 AM
bulldog's Avatar
Warning lights
I have a 1999 Alero. Over the last couple of days the ABS light has flashed on and off,also I was driving on the highway yesterday and the traction control light came on for a few minutes and then went out. The roads were bare and dry. Any ideas what could cause this. The garages around here want $125. to run a test on it.
Old Mar 1, 2012 | 11:14 AM
1970cs's Avatar
Lansing built
Problem
You may want to check automotiveforums.com/alero tab.
If memory serves me right that you have a wheel bearing going, it has the ABS sensor built in the hub assembly.
That subject should be in there multiple times.
Regards,
Pat
Old Mar 1, 2012 | 12:41 PM
cutlassgal's Avatar
Cutlass Lover
Check out this old thread. It may help you some!!
2001 alero
Old Mar 1, 2012 | 02:12 PM
Sounds like you took it to GM. A scan shouldn't cost 125.00 Most shops out here will do a scan for around 70.00. That's extra from the cost of the repair though. If it's the bearing and sensor this is the part, NAPA stocks it for left and right sides.
Old Mar 1, 2012 | 02:55 PM
Doc350s's Avatar
I'd agree with the previous posts. Most times the wheel speed sensor in the hubs either fail or if they are mounted externally to the hub are subject to rust jacking which causes the sensor to move out farther and lose signal. I've had a couple of GM vehicles do that. Cleaned one to get the rust off but had to replace the hub on the other. It usually manifested with the abs/parking brake lights and/or traction control. Just beware though the 2000 series Sierras went through a similar fault. When the abs system loses signal the computer may think the wheels are slipping at low speed and try to actuate the ABS. You will have a hard time stopping at slow speeds if the ABS kicks in.
Old Mar 1, 2012 | 03:45 PM
bulldog's Avatar
Thanks all. I guess I'll have to get it scanned.
foreverolds
Intrigue
Mar 20, 2013 01:56 PM
Tedd Thompson
Jun 5, 2012 09:50 AM
oldstuff
Sep 13, 2011 08:03 AM
Sid
Sep 10, 2010 02:33 AM
Dan Wirth
Aurora
Sep 18, 2009 06:56 AM
