AIC's build thread
AIC's build thread
I've owned my Alero less than a month, but have already started to make it mine. I keep a list of what I've done and what I plan on doing to it here. I'm not doing anything too crazy with it, as it is a daily driver, but I like to document what I do, and you'll find that here.
I'm a little late on getting this put together, so I've done a number of things already. Here is my list of things I've done:
1) door Speakers
2) Air Filter
3) New shocks/springs
4) upgraded Head unit with BT and USB (Yay audiobooks!)
Updated list of things I plan on doing soon
1) Oil change
2) install the tires I bought for it
3) Spark plugs
4) New sway bar links and bushings.
1) door Speakers
2) Air Filter
1) Oil change
3) Spark plugs
For the radio upgrade the parts I've used are the following:
Radio
http://amzn.to/1Vc4B0m
and then the parts needed to install it:
http://amzn.to/1WaGnmc
http://amzn.to/1SodvYq
http://amzn.to/1XDFr8T
video of the install:
Radio
For the spring/strut upgrade. I bought this set:
http://amzn.to/1Vc4li5
buying them as a set, something I had not done before, made the job a breeze and totally transformed my car.
Here is the video for that:
Replaced the spark plugs and the t-stat over the weekend. Spark plugs were pretty easy for a fwd v6 I didn't have to take anything apart. My infiniti I had to take 1/3 of the engine apart to do those.
My alero is NOT liking the AZ heat... Not sure how to approach that, but I guess a coolant flush is probably the first step.
I will check again, I checked a while ago (when I first got the car) and they both kicked on. I'll check tonight (have to wait till the sun goes down otherwise the car is too hot to touch).
The Stickman
Vista Cruiser & Wagons
104
Jul 24, 2013 05:44 PM
The Stickman
17
Mar 26, 2010 06:49 AM
