Tail Light Grommets?
Old Feb 5, 2013 | 03:50 PM
My442's Avatar
Question Tail Light Grommets?
Does anyone know if the rubber grommet that plugs into the upper trunk floor is reproduced?
It appears that this grommet is a part of the tail light housing assembly, and the 4 wires from the tail light passes thru it.
Over the years, they dry out and crack.
For a 1970 442
TIA
Old Feb 6, 2013 | 10:50 AM
ROCKET VAPOR's Avatar
Lance
http://www.fusickautomotiveproducts....sp?number=TB70
Old Feb 6, 2013 | 11:46 AM
fourtwenty's Avatar
Part Number - INL10645 1968-72 Olds Cutlass Trunk Wiring Harness Body Plug Each $14.00
From inlinetube.com
Old Feb 6, 2013 | 11:47 AM
fourtwenty's Avatar
fusik is 50 cents cheaper
Old Feb 6, 2013 | 12:51 PM
My442's Avatar
Thanks, but those are the wrong ones.
The grommets I am looking for have 4 tail light wires going thru them.
They push into the trunk floor near the latch.
The pictures you folks sent show the grommet that has the back up light wires and gas sender wire going thru it.
Old Feb 6, 2013 | 01:43 PM
I know which ones you're talking about. I looked at a spare set I have and they appear to have been molded onto the wires judging by the way the rubber is formed around the 4 wires on both sides. At any rate, when I tried pulling on the wires to see if they would move as in a loose grommet? No such luck.
Note glob on lower section. Upper grommet also has some fine join marks where the 4 wires go into the plug.
Old Feb 6, 2013 | 02:51 PM
jfb's Avatar
jfb
the grommet usually comes with a used or possibly if found new rear lights. I have used m and h wiring give them a call maybe they can hook u up.
Old Feb 7, 2013 | 09:19 AM
Lance
As others have stated, those grommets are part of the harness pig tail/ tail lamp assembly. I dought anybody would carry these as a seperate items.
Old Feb 7, 2013 | 09:56 AM
My442's Avatar
It appears that the grommet is molded in place, capturing the wires.
My bet is GM bought the housing assembly from a vendor, thus the lack of spare grommets.
All the assemblies that I have seen have rock hard grommets from age.
I will look to see if I can find a replacememt somewhere.
Old Feb 7, 2013 | 10:01 AM
Lance
Paul have you tried laquer thinner to try to soften-up the old rubber, and maybe black weatherstip adhesive to repair the tears?
Arrowstorm
Oct 31, 2014 07:41 AM
RAMBOW
Dec 27, 2013 06:48 PM
Vader
Sep 11, 2013 07:01 AM
tcarroll
Aug 3, 2012 05:16 PM
Joeypete
Brakes/Hydraulic Systems
Jan 20, 2010 07:09 AM
