Removing back panel on bucket seats
Old Jan 5, 2013 | 09:43 AM
randomarrival's Avatar
Any suggestions on how to remove the seat release button in the center of the back of these bucket seats? Or how to remove the whole panel?
Thanks!
Old Jan 5, 2013 | 11:04 AM
2blu442's Avatar
You'll need to gently pry it out. What's been suggested as useful is to take two putty knives and wrap some electrical tape around them to protect the plastic back. Then gently work from opposite sides prying up. Eventually it will pop out, but the outside trim around the button is plastic and can break easily so don't get in a hurry. It's been a while since I've removed one of these but I have some seat backs in the garage if it would help to see pictures. From what I remember there's two screws at the bottom where the seat back meets the seat bottom. Once you have the release button removed and these two screws pull the bottom out and push up. There's two "hooks" cast into the plastic that fit into the metal framework of the seatback. You'll need to push up to get it off these. John
Old Jan 5, 2013 | 11:16 AM
69442C's Avatar
There are spring clips on the sides of the button so as John suggested, use putty knives to push them in and it should pop up and off. There will be another screw behind this button that holds the seat back in place and there will likely be 3 screws at the bottom. Once these screws are removed, pull the bottom out slightly and push up like John mentioned.
Brian
Old Jan 5, 2013 | 11:42 AM
Putty knives worked great, once I got it pried up a bit I did slide in a screw driver to release the clip, putty knives I was using weren't stiff enough.
Thanks for your help here!!
kjr442
Jun 16, 2015 07:33 PM
srbz
Apr 10, 2015 06:53 PM
eddie160
Nov 21, 2012 03:37 AM
dallas*fan
Oct 19, 2011 05:00 PM
wikkonado
May 24, 2010 10:58 PM
