Which repop air filter to use with OEM pie tin?
Old Apr 23, 2011 | 07:25 PM
OLDSmobility's Avatar
I want to install an original-style air filter on my '67 and use the OE 442 pie tin, like in this shot:
So I was hoping someone could point me in the direction of an aftermarket assembly that closely mimics the OEM lid shape that will enable me to use the factory pie tin.
Old Apr 23, 2011 | 08:10 PM
Rickman48's Avatar
I kind of prefer the K+N filter for the increase in power, and a little more modern look.
AC Delco filters were the original, and look more correct than any others.
Old Apr 24, 2011 | 04:38 AM
jensenracing77's Avatar
i don't know what aftermarket filter the tin will fit but that picture is likely the factory 67 442 4 speed filter. i have seen many aftermarket ones that look similar but don't know if the tin will fit the contour right.
Old Apr 24, 2011 | 06:46 AM
Thanks for the replies. So is the factory filter assembly available as a repop? For my purposes I don't need OEM...those are better off in the hands of someone doing a correct restoration.
Old Apr 24, 2011 | 07:29 AM
rocketraider's Avatar
Oldsdruid
Pretty sure that's just a standard 14" diameter filter, same as any AC A212CW.
Which incidentally is what the parts book calls for on 1966-67 400 engines except OAI.
So you should be able to use any 14" diameter filter element in any height that will fit underhood. A 3" height is OE, but 4" and 5" height will pass more air.
Old Apr 25, 2011 | 06:54 PM
tecar442's Avatar
I got mine from Fusick.
Hairy Olds
Oct 6, 2019 06:32 AM
JPMDaddy
Jan 14, 2019 08:41 PM
costpenn
Apr 4, 2015 03:23 PM
Aedwards
May 31, 2011 08:34 AM
