bypass hose used in other GM models ?
Old May 29, 2010 | 10:34 PM
alexrains's Avatar
I am desperately seeking the molded bypass hose (thermostat to water pump) with GM part# 393508.
As I live in Europe and need the part on this Wednesday the latest (we have a rally on the weekend), can somebody please tell me, if that hose is used in other vehicles as well (maybe Jeep or Pontiac, which are more common around here) ?
With that info, I could browse "local" shops, as shipping from the States will take too long...
Thank you for any hint !
Alex.
Old May 30, 2010 | 02:40 AM
Bluevista's Avatar
Registered
Washing machine rubber discharge hoses are curved like that to hook on the edges of utility sinks.
Probably too big though.
The parts stores here have the molded heater hoses hanging up with radiator hoses, lots of newer cars use them. You may find one with the right curve that could be cut to fit if they have those there?
I looked at Rockauto, they have the cross reference charts with the parts.
How about a 1990-1994 Nissan pick-up truck?
Dayco 70476 bypass hose;
NISSAN D21 PICKUP (1990 - 1994)
NISSAN D21 PICKUP XE 1994
OLDSMOBILE 442 (1965 - 1971)
OLDSMOBILE 98 (1965 - 1971)
OLDSMOBILE 98 HOLIDAY (1965 - 1967)
OLDSMOBILE CUSTOM CRUISER 1971
OLDSMOBILE CUTLASS (1964 - 1971)
OLDSMOBILE CUTLASS HOLIDAY (1964 - 1966)
OLDSMOBILE CUTLASS S 1971
OLDSMOBILE CUTLASS SUPREME (1968 - 1971)
OLDSMOBILE DELMONT 88 (1967 - 1968)
OLDSMOBILE DELMONT 88 HOLIDAY 1967
OLDSMOBILE DELTA 88 (1966 - 1971)
OLDSMOBILE DELTA 88 CUSTOM (1968 - 1971)
OLDSMOBILE DELTA 88 HOLIDAY (1966 - 1967)
OLDSMOBILE DELTA 88 ROYALE (1970 - 1971)
OLDSMOBILE DYNAMIC (1965 - 1966)
OLDSMOBILE DYNAMIC HOLIDAY (1965 - 1966)
OLDSMOBILE F85 (1964 - 1971)
OLDSMOBILE F85 HOLIDAY 1966
OLDSMOBILE JETSTAR 88 (1964 - 1966)
OLDSMOBILE JETSTAR 88 HOLIDAY (1964 - 1966)
OLDSMOBILE TORONADO (1966 - 1971)
OLDSMOBILE VISTA CRUISER (1964 - 1971)
Goodyear 63602;
CHEVROLET CORVETTE 1967
OLDSMOBILE 442 (1965 - 1969)
OLDSMOBILE CUTLASS (1964 - 1969)
OLDSMOBILE CUTLASS HOLIDAY (1964 - 1967)
OLDSMOBILE CUTLASS TURNPIKE CRUISER 1967
OLDSMOBILE DELTA 88 (1965 - 1969)
OLDSMOBILE DELTA 88 CUSTOM (1968 - 1969)
OLDSMOBILE DELTA 88 HOLIDAY (1965 - 1967)
OLDSMOBILE F85 (1964 - 1969)
OLDSMOBILE F85 DELUXE 1965
OLDSMOBILE STARFIRE (1965 - 1966)
OLDSMOBILE TORONADO (1966 - 1969)
OLDSMOBILE VISTA CRUISER (1964 - 1969)
OLDSMOBILE VISTA CRUISER CUSTOM 1965
PLYMOUTH SATELLITE 1965
Gates 20333;
DESOTO ADVENTURER 1957
DESOTO FIREDOME 1957
DESOTO FIREFLITE 1957
DODGE 330 (1963 - 1964)
DODGE 440 (1963 - 1964)
DODGE CHARGER 1966
DODGE CORONET (1959 - 1966)
DODGE CORONET 440 (1965 - 1966)
DODGE CORONET 500 1966
DODGE CORONET DELUXE 1966
DODGE D100 SERIES (1961 - 1966)
DODGE D200 SERIES (1961 - 1966)
DODGE D300 SERIES (1961 - 1966)
DODGE DART (1960 - 1962)
DODGE POLARA (1963 - 1966)
DODGE W100 SERIES (1961 - 1966)
DODGE W200 SERIES (1961 - 1966)
DODGE W300 SERIES (1961 - 1966)
DODGE WM300 POWER WAGON (1961 - 1962)
OLDSMOBILE CUTLASS SUPREME (1967 - 1971)
OLDSMOBILE DELTA 88 (1965 - 1971)
OLDSMOBILE JETSTAR I 1965
PLYMOUTH BELVEDERE (1956 - 1966)
PLYMOUTH BELVEDERE II (1965 - 1966)
PLYMOUTH CUSTOM (1958 - 1959)
PLYMOUTH FLEET SPECIAL (1960 - 1963)
PLYMOUTH FURY (1956 - 1966)
PLYMOUTH FURY II (1965 - 1966)
PLYMOUTH FURY III (1965 - 1966)
PLYMOUTH FURY SPORT 1966
PLYMOUTH FURY VIP 1966
PLYMOUTH PLAZA (1956 - 1958)
PLYMOUTH SATELLITE (1965 - 1966)
PLYMOUTH SAVOY (1956 - 1964)
PLYMOUTH SPORT WAGON (1960 - 1961)
PLYMOUTH SUBURBAN (1956 - 1961)
http://www.rockauto.com/
Old May 30, 2010 | 02:58 AM
alexrains's Avatar
Great, thank you !
But actually none of these cars are common (or even available) in EU...
Old May 30, 2010 | 10:40 PM
Run to Rund's Avatar
Around 1971 Olds had a "campaign" to replace all the aluminum water necks with J shaped bypass hoses to the iron neck, J pipe pressed in, and straight piece of hose to the water pump. Maybe you can find the later neck.
squirell
Sep 22, 2013 02:17 PM
my71olds
Apr 28, 2013 06:08 PM
ROCKET VAPOR
Jul 10, 2012 08:50 PM
at3reg98
May 4, 2012 08:22 PM
J'ville
Sep 24, 2010 02:30 PM
