71 455 Intake manifold fitting/O.A.I
Old Dec 8, 2009 | 06:00 AM
fjross's Avatar
Can anyone help me with what type thread the hole is at the bottom of the attached photo. I'm assuming that this is a barbed 90 degree vacuum fitting that goes to the air cleaner heating element. Would anybody know where to get one of these or happen to have one for sale? This thread seems coarser then 1/8" npt yet smaller in diameter. The service manual and assembly manual is not very clear on the hose routing for OAI, and shows both applications for TCS and distributor vacuum control switch. Am I correct in assuming that I should only have the DVC switch? If any one could help me with the vacuum hose routing for the OAI it would be greatly appreciated.
Old Dec 8, 2009 | 06:45 AM
If you are talking about the boss shaped like an "8" with two holes, that is where the carb dashpot bolts up. Those are blind holes. One is simply a straight drilled hole for the locating tab on the dashpot bracket and the other is a tapped hole for the bolt that retains the dashpot.
Old Dec 8, 2009 | 07:59 AM
fjross's Avatar
Thanks Joe, I looked back on my disassembly pics and just found a bolt in the hole that I was questioning about. My previous owner must have taken the dashpot off and never replaced it. For some reason, this lower hole is not blind, but a thru hole. I guess I have to start looking for a dashpot with bracket and hardware.
Thanks Dave
defiant1
Jun 17, 2013 09:36 AM
KZ442
Feb 4, 2011 09:26 PM
ddx77
Jun 3, 2010 10:11 AM
|-K|=K
Oct 1, 2009 07:37 PM
Pfiffle
Oct 1, 2008 02:07 PM
