Backing up, hear clicking
Old July 2nd, 2022, 04:42 PM
NoVA_69_442's Avatar
Got another issue. In reverse, I hear and feel a clicking sound, sounds like it’s coming from passenger front but can’t be 100% as I’m in the car backing it out.
didn’t change anything with suspension, swapped out fans, thought that might be hitting radiator but it isn’t, any ideas?
i raised the front end of the car turned wheels all the way in out out to see if there were catching on something, they weren’t. The spin freely.
NoVA_69_442 is offline
Old July 2nd, 2022, 04:49 PM
Sugar Bear's Avatar
One click, repeated clicks? Does the rate of clicking change if you back up faster or slower? Turning or in a straight line?
Sugar Bear is online now
Old July 2nd, 2022, 09:14 PM
edzolz's Avatar
Check your U joints.
edzolz is online now
Old July 3rd, 2022, 05:56 AM
Could be u-joints, could be wheel bearings.
joe_padavano is offline
Old July 3rd, 2022, 07:52 AM
It is a repeated click and it does appear to increase with the rate of speed. I did try to roll down my driveway, which is on an incline, with the car in neutral and there didn’t appear to be any clicking sounds.
not sure if this means it’s reverse gear in the Trans or something else.
thanks for any help.
Old July 3rd, 2022, 08:26 AM
Sugar Bear's Avatar
Is this on the '69 442? Auto or manual transmission?
If there is any wheel trim remove it and test. Do look at the universal joints as suggested, a driveshaft dropping out is the start of a bad day. If you're not familiar with how to check the u-joints just ask.
Good luck!!!
Old July 3rd, 2022, 10:18 AM
Shift from drive to reverse a few times and listen for firm load shift, or clunk clunk clunk. That's U joints if so.
Can reverse load the engine to lift off a bad right motor mount and start banging fan? I don't really think so.
Koda is offline
cmpcpro
November 28th, 2016 10:18 PM
jaunty75
October 19th, 2013 07:36 PM
rcdynamic88
August 29th, 2013 12:46 PM
dewcrazzy
June 24th, 2013 05:02 PM
71CutlassSupreme
October 29th, 2011 12:30 PM
Quick Reply: Backing up, hear clicking
