1969, 442
Old May 17, 2020 | 10:34 AM
Neil Morrison's Avatar
1969, 442
What is the factory setting for the Rochester 4bbl carb Fuel and air mixture screws.
2 turns out, 3 turns out ???
Thanks if you know.
Old May 17, 2020 | 11:32 AM
Thanks if you know.
You might get more responses if you use a descriptive title on your posts. You've got what, three or four different threads going with this same title and different topics?
To your question, the factory setting is the one that gives you the maximum vacuum reading using a vacuum gauge. Three turns out is where you start when you rebuild the carb. The idle mixture screws need to be adjusted on the car to the setting the engine wants.
Neil Morrison
May 16, 2020 03:18 PM
Neil Morrison
Apr 30, 2020 11:42 AM
Neil Morrison
Apr 26, 2020 10:16 AM
Jerry0726
Oct 1, 2019 09:29 AM
