Oshawa 442 production numbers
Old Jan 30, 2020 | 01:22 PM
Doug Carner's Avatar
69 Ol' Blue
I have a 1969 442 thatbwaa made at the Oshawa Ontario plant and I was wondering if anyone new where I could find the production numbers. I would really like to narrow it down to how many of those were holiday couples with 4 speed, 3.91 gears, bucket seats, vinyl roof, air conditioning, floor console and Trophy blue metallic paint.
Any information is appreciated.
Old Jan 30, 2020 | 03:48 PM
rktolds's Avatar
maybe GM of Canada? They have records like Pontiac Historic Services.
Old Jan 30, 2020 | 06:27 PM
69 Ol' Blue
Thanks a bunch!
Old Jan 30, 2020 | 09:58 PM
oldsmobiledave's Avatar
records exist for production by body type (hardtop. Coupe, or convertible) and by transmissions but there are no other records based on individual options or paint color.
Old Jan 31, 2020 | 06:48 AM
sherlock1212's Avatar
Here is a guy that can get you what you need I had him do a paper on my 68 cutlass He has access to G M documents at the Oshawa Plant it's Frank at 1905-440-7618 his web site is www.vintagevehicleservices.com Good luck
Old Jan 31, 2020 | 07:45 AM
Neil Morrison's Avatar
GM of Canada only send you to Vehicle Heritage site and they want $125 for info.
Old Jan 31, 2020 | 08:48 AM
stan 65 cutlass's Avatar
they do charge for the info, when i got my 65 search done i also got options and paint info, key codes etc
Old Jan 31, 2020 | 05:41 PM
One other note. 1969 Canadian made 442s used the Chevy 12 bolt rear end for which 3.91 gears were never an option. Perhaps your car has 3.73 gears? VVS can tell you how your car was equipped.
Old Jan 31, 2020 | 05:56 PM
Diego's Avatar
Old Jan 31, 2020 | 05:57 PM
This page from the 1969 SPECS booklet shows the ratios offered for the Canadian-built cars with the Type C axle. See the notes in the box under "Axle Option Numbers".
Old Jan 31, 2020 | 06:04 PM
Originally Posted by Diego
those are my docs for one of my 1969 442s now owned by my buddy Randy aka Fred Flinstone.
Old Jan 31, 2020 | 07:29 PM
69 Ol' Blue
Great info guys. Thanks! I did a little research in the Olds 442 Restoration guide and found codes for the rear axle. My code (TO) revealed that it has the 3.91 gears. It all looks original to the car. Could it have been a special order?
Old Jan 31, 2020 | 10:45 PM
The Type O diff was not used at Oshawa in 1969. It can't be original to the car.
jeff depietro
Jul 18, 2016 07:37 PM
Stevec
Nov 12, 2010 01:57 PM
landyacht1
Jun 10, 2010 07:51 PM
mugzilla
Mar 6, 2009 05:43 AM
real442
Jan 25, 2008 06:21 AM
