Heater box
If the factory non-A/C box fit, there would be no market for the aftermarket part.
Yes, the firewall cutouts for A/C are much larger than the ones for heater-only.
And keep in mind that the heater-only box is cable operated. The A/C box is vacuum operated. The A/C delete retains the vacuum operated part under the dash so you still have heat and defrost. It only deletes the A/C evaporator under the hood.
