Heater box
Old Nov 18, 2019 | 05:21 PM
David Handlos's Avatar
Heater box
Took fac air out of 1971 442 (455 motor) will non fac air heater box fit or do I have to order AC delete cover from OPG
Old Nov 18, 2019 | 06:11 PM
If the factory non-A/C box fit, there would be no market for the aftermarket part.
Yes, the firewall cutouts for A/C are much larger than the ones for heater-only.
And keep in mind that the heater-only box is cable operated. The A/C box is vacuum operated. The A/C delete retains the vacuum operated part under the dash so you still have heat and defrost. It only deletes the A/C evaporator under the hood.
67Rocket
Apr 2, 2018 12:41 PM
6844268
Nov 10, 2016 05:26 AM
44blue
Aug 28, 2015 04:54 PM
madmax442
Body work
Jan 22, 2014 07:32 AM
jeffs 89 cutlass salon
Oct 7, 2007 05:59 PM
