Heater deleted
Old Jan 21, 2014 | 06:00 AM
madmax442's Avatar
Heater deleted
Can anyone give me an opinion on what I should do to get my former a/c car now drag car back on the road with atleast a heater/defrost unit? I've seen vintage air units but I'd like some input thanks.
Old Jan 21, 2014 | 07:13 AM
How much of the duct work and controls is left under/in the dash and what did you do to the firewall where it all used to be?
Old Jan 21, 2014 | 09:00 AM
Your biggest concern is what was done to the hole in the firewall for the HVAC box? The A/C firewall hole is larger than the one for heater-only cars, so unless you plan to weld in new metal, you're stuck using the A/C HVAC box. If you don't plan to run A/C, you can get an aftermarket "A/C delete" box that covers the hole but eliminates the A/C evaporator, making the box smaller. You still need to use the stock A/C box under the dash and the A/C dash controls, including the vacuum activated flapper doors.
If you want to convert to a factory style heat/defrost only, you'll need to weld up or otherwise cover the A/C hole in the firewall, cut a new hole that's the correct size for heat-only, and install all the heat-only parts on both sides of the firewall.
Old Jan 21, 2014 | 03:25 PM
madmax442's Avatar
I guess my pic showing the firewall didn't load! It was welded shut.!
Old Jan 21, 2014 | 03:45 PM
Mr Nick's Avatar
Could you get one of these under the dash?
http://www.summitracing.com/parts/flx-640/overview/
Dimensions don't seem too bad.
Old Jan 21, 2014 | 05:08 PM
madmax442's Avatar
Thanks! Never seen that before!
Old Jan 21, 2014 | 08:37 PM
dfire25's Avatar
"Trying to fix her right"
Don't you have that backwards?
Old Jan 22, 2014 | 04:32 AM
madmax442's Avatar
I was hoping to not have to reopen the newer smoothed firewall. Hopefully I can put a smaller electronic unit in behind the dash that will fit!
Old Jan 22, 2014 | 04:45 AM
dfire25's Avatar
If all your duct work and controls are gone you could use a VA unit. All the hoses are run threw the old fan hole under the fender. You will have to fab up a way to mount the unit to the firewall. If you weld the mounting plate to the firewall that should work, that's what I was going to do but I went in a different diffection. I wonder if VA makes a heat only unit if you don't want the A/C. Here's how I did mine.
Old Jan 22, 2014 | 05:07 AM
madmax442's Avatar
Yes va does make a heat only unit. Yours looks great different!
Old Jan 22, 2014 | 05:08 AM
madmax442's Avatar
Autocorrect is a horrible feature!
Old Jan 22, 2014 | 07:32 AM
dfire25's Avatar
Thanks! I would definitely go with a VA unit then. Some guys have said that the heat isn't quite as good as the factory unit, but I don't think its bad.
The only thing I've noticed is that its a little loud. The fan is in the passenger compartment now instead of outside on the firewall, so the fan noise is a little loud. But that don't matter as long as you have heat.
turnpike_cruiser
Non-Olds Engines
Aug 16, 2011 07:12 PM
fast67vellen2o
Aug 31, 2010 09:52 AM
scubastever
Site Help
Mar 3, 2009 11:42 AM
