Will any '68 parts work?
Old Jun 14, 2018 | 07:35 PM
Carsick's Avatar
I've found a 68 442 (no pictures yet) and would like to know if any parts will fit on my 69 442. I'm mainly interested but may buy the whole car depending...
Old Jun 15, 2018 | 09:59 AM
Depends on which parts you are talking about and what the two body styles are.
Old Jun 15, 2018 | 10:38 AM
Carsick's Avatar
Thanks Joe
Maybe the doors (assuming it's a post) but mainly the frame. Also Maybe the booster/cylinder and evaporator box (I doubt that's the right name)
Old Jun 15, 2018 | 10:43 AM
Frames are the same. Post doors are the same (well, not quite sure about the lock **** location on post doors). Firewall and everything on it is the same (though a 69 will have an internal regulator, a 68 has the external regulator on the firewall). Inner fenders are the same. Floor pan is the same. Suspension and brakes are the same except that the optional disc brakes were four piston calipers in 68 and single piston in 69. Drivetrain is essentially the same. Dash pad is the same EXCEPT that all 69 hardtops and converts used the A/C pad even with non-A/C due to the upper vents. Post cars with out A/C used the same pad without the vent holes. Roof is the same Glass is the same (excepting the HT/convert door glass). The rest of the sheet metal is different.
Old Jun 15, 2018 | 10:47 AM
Carsick's Avatar
Thanks for all the good info Joe. Ill post pictures soon ( none yet)
alburk
Body work
Aug 30, 2018 10:07 AM
rcktdoc
Jan 28, 2018 02:22 PM
kevdog442
Jul 27, 2016 05:22 PM
getawaycar
May 30, 2011 03:55 PM
mcutlass1969
Jan 31, 2011 06:14 PM
