turn signal switch not cancelling
Your canceling springs are broken.
In addition to information available on this site about this, there is a nice description of how to fix them here.
This guy has done an impressive amount of work in illustrating the takedown and function of a slightly later, but essentially identical, tilt column.
The springs should be on a HELP! card at your local auto parts store.
Glad to help out.
I find things using a combination of memory (for the name of the part and the nature of the problem) and Google. I knew that the problem was caused by broken turn signal canceling springs, so I googled that, looked at the results, and posted the better ones.
It's sheer laziness, really - I just didn't want to write up a whole description of the repair (which is very simple once you do it) myself .
costpenn
June 24th, 2015 10:38 PM
dennisspeaks
October 1st, 2011 06:02 PM
