Shifter cable question?
Old August 9th, 2014, 09:45 AM
nitrovette's Avatar
I have installed a hurst lighting rod shifter into my Grand National and notice that when the cable is hooked up its sticky to shift but when you remove the cable the shifter works smooth is this a cable problem its old so just wanted to see what anyone might know here about this problem before I put every thing back together. Would a new cable fix this of is this just a normal problem anyone?
nitrovette is offline
Old August 12th, 2014, 04:15 PM
BlackGold's Avatar
It's very likely that one of more of the strands of your cable has broken inside the sheath and is creating friction. Replace it before it either strands you (by not letting you shift in or out of gear) or makes you break something (by pushing too hard on the shifter). Ask me how I know this (though my experience was with a standard G-body shifter, not lightning rods).
BlackGold is offline
defiant1
February 4th, 2020 08:53 PM
rootney
June 27th, 2014 11:30 AM
dmberendsen
April 10th, 2013 03:18 PM
Guttermouth
July 30th, 2012 06:58 AM
weasel
February 8th, 2011 07:36 PM
Quick Reply: Shifter cable question?
