Problems starting from a stop
Old Sep 18, 2012 | 08:13 PM
patmills's Avatar
442forsure
I have a '66 442 with an M21 close ratio. I also have a 425 with tripower. I understand the engine has a W30 cam in it. It does not like to start off at an idle which is what is causing my problem. I have to ride the clutch to get it moving and I think I have caused glazing on the clutch as it has begun to "judder" a lot when starting off. When I bought the car I was told that my differential ratio was 3:55. When I had the car apart for the restoration I checked by turning the driveshaft and counting wheel turns and I thought it was 3:90 or 4:11. During the restore, I had the transmission rebuilt, turned the flywheel, and put in a new stock clutch according to the specifications of the car. I have not driven the car a lot of miles since the restore and I have not been hard on the clutch.
I drive big truck on the highway so I do know how to use a manual transmission and clutch.
Does anyone have a solution to my situation? If I had bags of money I would put a 6 speed Tremec with a low first gear and I know that would solve the problem but is there anything else I can do? Would a ceramic clutch face be a solution?
Pat Mills
Old Sep 18, 2012 | 09:58 PM
Rickman48's Avatar
A M-20 would be a better solution.
Did that same swap on a '67 BB Impala last year, with a 3:42.
Owner didn't believe it was the same car!
Old Sep 18, 2012 | 10:27 PM
patmills's Avatar
442forsure
Thank you - didn't think of that.
Pat
Old Sep 19, 2012 | 07:17 AM
Rickman48's Avatar
Let us know how it works out!
Old Sep 19, 2012 | 08:08 AM
patmills's Avatar
442forsure
Will do. Would you use the stock clutch? If not what would you use?
Pat
Old Sep 19, 2012 | 08:20 AM
Rickman48's Avatar
You could just 'break the glaze' on all parts - I'd think, being new, it should be OK.
Some don't realize that getting your foot off the clutch asap adds longevity!
Don't slip it - let the motor do the work!
And if it slips when you 'stand on it', clutch fully engaged, somethings not right!
Old Sep 19, 2012 | 09:03 AM
patmills's Avatar
442forsure
Thanks again for the advice and yes I fully appreciate what riding the clutch does.
How would you "break the glaze" ?
Old Sep 19, 2012 | 11:58 AM
Rickman48's Avatar
80 grit on a sanding block powered by elbow grease!!
All contact areas.
Didn't mean riding the clutch - meant getting it fully engaged asap, without or with very little slippage!
Once had a neighbor with a 300 Z, asked him how he liked it - he said "fine, but he was on his 4th clutch in 60k miles!"
Heard him take off once, and he slipped it almost all the way through 1st!!
But he was one of those guys you couldn't say anything to, so I didn't.
Another friend put 140k on his ford ranger clutch - but knew how to drive stick.
Old Sep 19, 2012 | 01:16 PM
patmills's Avatar
442forsure
Thanks for the information. And I fully agree with you about using a clutch properly.
With a big truck you don't touch the fuel til you have it rolling with the clutch right out.
Am going to try and find a M-20.
Old Sep 19, 2012 | 01:31 PM
Sometimes if the adjustment is not quite right, pilot bearing worn, throwout bearing worn, weak pressure plate, will cause a chatter.
Old Sep 19, 2012 | 03:28 PM
Dave Siltman's Avatar
If you can't find an M20, you can change the first gear in that M21 to a 2:52. The shop that rebuilt the trans. can do it and may even have the gear.
Old Sep 19, 2012 | 03:33 PM
Oldsmaniac's Avatar
Well you always must increase the rpm/pedal pressure while getting the car to start from a stop. If you try and do it at idle speed it will stall or you will need to "ride the clutch". I assume the rpms come up normally when in neutral and pressing on the accelerator. With a w30 cam I would have my idle speed at about 950 rpm or so.
Old Sep 28, 2012 | 07:33 PM
patmills's Avatar
442forsure
Thanks for all your suggestions. I am going to try and trade my transmission for a M-20 because Reverse in a M-21 is really high too.
Old Sep 28, 2012 | 09:59 PM
RandyS's Avatar
If your rear gears are 3.90 or more, an M21 should work real well. Your clutch should be fully engaged at only a few MPH. (I have owned a 66 with that exact configuration). I would suspect the pressure plate. Is it a stock diaphragm, or a Borg & Beck style with the 3 arms? The Borg & Beck style can get out of addjustment, and if the plate is not meeting the disc evenly, that will cause chatter. Glazing usually causes slippage rather than chatter, and can be cured with some elbow grease as noted. (you do have to pull the clutch to do it)
Old Sep 29, 2012 | 06:45 AM
Lady72nRob71's Avatar
So the engine is running fine? Not feeling like it wants to stall?
chasman414
Jun 25, 2020 07:05 AM
bccsrc
Nov 29, 2011 11:08 PM
bebufire
Jun 26, 2011 02:48 AM
VikingBlue
Oct 23, 2010 08:39 AM
justinj
Nov 4, 2008 10:56 AM
