plug wires for olds 400 cu.in
Old Jul 14, 2014 | 05:55 PM
hobs's Avatar
I need to replace the plug wires on my '69 442...400 cu. in.
#8 plug wire with the straight boot is REALLY tight...the wire's bent at a 90 and i think i should put a 90 degree boot on it. Anybody else have this issue/concern, and has anyone got a wire set with the L boot on the plug end?
Thanks!
Old Jul 14, 2014 | 08:11 PM
rcorrigan5's Avatar
Randy C.
I got the spark plug wire set for my '68 4-4-2 from Fusick. Look at www.fusick.com for part number 1Q69 for your car. I've had mine since 2007 and they fit nicely and are still working fine.
Randy C.
Old Jul 14, 2014 | 08:18 PM
tecar442's Avatar
I got mine from Fusick also. 6 years, no problems.
Old Jul 14, 2014 | 08:45 PM
Macadoo's Avatar
I picked up a set of boot-yur-own Accel wires with right angle boots from Autozone, 8mm. A few of the boots lay directly on the header flange but so far no problems. At first I regretted it but after seeing the clearance at the AC box and the AC bracket, I'm not sure how I would have gotten straight boots in there.
Old Jul 16, 2014 | 05:22 PM
Jonb442's Avatar
My '69 still has the Moroso Blue Max wires I put on it in the early nineties. They're universal fit and all straight boot, but I managed to bend the boot for #8 enough to clear the evaporator case.
Old Jul 21, 2014 | 01:03 AM
Yellowstatue's Avatar
I believe the plug boots are 45*, not 90*
Old Jul 21, 2014 | 06:09 AM
mrolds69's Avatar
Buy repro wires, expensive...but they will fit great! Original wire boots + terminals were not straight, 45 or 90 degrees. They were almost straight, with a small bend in them so you could adjust them a little, like around the AC box.
BeenThere
Jan 19, 2016 10:34 AM
Hawghead
Jul 18, 2014 12:51 PM
MJAKS462
Apr 1, 2010 05:04 AM
327supreme
Feb 15, 2009 05:45 PM
dan2286
Feb 5, 2009 06:42 PM
