PCV to carb question
Old Apr 27, 2012 | 06:28 AM
69'442's Avatar
I have a 70 442 automatic with OAI. The venting was set up incorrectly. It had both valve covers vented to the air cleaner and no pcv valve. The hole on the bottom front of the carb was plugged. It ran good. I changed to the right configuration. The driver side valve cover got a pcv valve with a hose to the carb. Passenger side vented to the air cleaner. The car seems to want to stall. Would I have to adjust the carb after this change? Not sure what to do. Thanks
Old Apr 27, 2012 | 06:40 AM
Not that it matters a whole lot but the pcv goes on the passenger side. Reason is because its usually the side with the baffle. I have run into bad pcv valves over the years, are you sure it's working correctly?
If the pcv is operating correctly, what are your tuneup specs set at?
Old Apr 27, 2012 | 08:55 AM
hookem horns's Avatar
Wonder why this was done in the first place since the PCV system is simple, effective and does not affect performance. Any restrictions in the air cleaner vent? Good vacuum from the carb to PCV valve?
Old Apr 27, 2012 | 08:56 AM
69'442's Avatar
The manual shows mine on the drivers side. I will replace the pcv valve with a new one and see what happens. Thanks
Old Apr 27, 2012 | 09:04 AM
69'442's Avatar
I think it was done because the manual is a little confusing with the OAI setup. W30's and manual transmission cars had the lines from both valve covers to the air cleaner and pcv from the intake to the carb. Automatic OAI cars did not have the port for the pcv in the intake manafold. So I guess they set it up like a w30 but with no pcv valve. Does it affect the carb to have the vac line plugged verses the valve cover pcv with hose attached to it?
Dead Reckon
Non-Olds Engines
May 18, 2015 08:29 AM
oldrelics
Jul 28, 2014 03:28 PM
tomngary
May 19, 2014 11:24 AM
jstrits
Nov 26, 2011 05:58 AM
DJS70cutlass
Sep 23, 2011 12:24 PM
