Original engine check?
Old January 24th, 2017, 10:55 AM
84venom's Avatar
New to 442s. We have a very nice '70 that we will be selling, but need to confirm if the original engine is in the car. Hope someone can point me in the right direction. Thanks!
84venom is offline
Old January 24th, 2017, 11:03 AM
Check the block VIN pad to see if it matches the last six digits of the vehicle VIN. Also make sure it is actually a 455 with E heads.
Yours should start with 30 for Olds, 1970 model year.
Fun71 is online now
Old January 24th, 2017, 11:36 AM
84venom's Avatar
Thanks, do you know what each individual number means? I don't think it's just the VIN on there is it?
84venom is offline
Old January 24th, 2017, 12:20 PM
First number is Oldsmobile division = 3
Second number is year of manufacture = 0 for 1970
Third letter is assembly plant (I don't remember all of them right off)
Four - nine = vehicle's assembly sequence number and should match the numbers on the body VIN plate
edit: I found this info for assembly plant codes
1 Oshawa, Canada
C Southgate, CA
D Atlanta, GA
E Linden, NJ
G Framingham, MA
M Lansing, MI
X Kansas City, KS
Z Fremont, CA
Fun71 is online now
Old January 24th, 2017, 01:02 PM
72 Olds CS
RetroRanger's Avatar
here
RetroRanger is offline
Old January 25th, 2017, 06:07 AM
Here's an even simpler explanation. The stamped number on the block (and transmission case) is called a VIN derivative because it contains only nine of the 13 characters in the original VIN of the car. If this is the original block, the first character of the VIN derivative stamp will match the first of the VIN, and the last eight of the VIN derivative stamp will match the last eight of the VIN.
joe_padavano is online now
Old January 26th, 2017, 05:47 AM
lemoldsnut's Avatar
Tagging in to save this. Great thread.
lemoldsnut is offline
jensenracing77
July 16th, 2013 06:41 PM
fastflyer
March 1st, 2011 04:45 AM
JACK RYAN
Intrigue
December 28th, 2008 09:27 PM
sean000
January 31st, 2007 05:03 PM
Iron Chef Ajax
Intrigue
August 7th, 2006 08:36 AM
Quick Reply: Original engine check?
