Need help identifying these part
Old April 6th, 2016 | 01:51 PM
benjamin247's Avatar
Hello,
I need help identifying these parts. The previous owner gave them to me and said he planned on putting in AC and these are some of the parts for it.
Old April 6th, 2016 | 02:06 PM
Rustbucket2's Avatar
Ok, first one is ac/heater box, goes on outside firewall. second picture is starter, bolts to bottom side of engine and turns engine over to start car.
Old April 6th, 2016 | 03:52 PM
cool...thank you!
Old April 7th, 2016 | 10:19 AM
AzMotorhead's Avatar
Benjamin427 the First part you have circled is the underhood"suitcase" for the AC system. In that case is the evaporator. The big valve that comes out of the top is the POA or Throttle suctioning valve. The valve on the bottom line is the expansion valve, Both of those parts are going to be GM A body specific.
You need to know if your car was originally equipped with AC for the suitcase to fit to the firewall. Sure it may physically fit on the firewall, but the hole cutout in the firewall is different from an AC to NON Ac car
Old April 7th, 2016 | 10:36 AM
Is there a way for me to tell if my car is originally an AC or NONAC car?
Old April 7th, 2016 | 10:38 AM
Well, is the control panel on the dash for heat only or for heat and A/C?
Old April 7th, 2016 | 11:02 AM
Post a picture of your firewall ,passenger side. We'll be able to tell you
Old April 7th, 2016 | 11:05 AM
Looks like in your first picture. There's a AC compressor in the box, also a alternator bracket. Chances are you have a non AC car and the PO was collecting parts thinking it would be a easy swap over.
Bolting on parts is easy. Cutting and patching the firewall sux
Old April 7th, 2016 | 12:06 PM
Octania's Avatar
The firewall hole to mate the AC evaporator shown is substantially larger than the oh 8x10" hole covered by oh 12x24 plenum seen on heater-only cars.
Rustbucket, congrats on the restraint there. Just the facts. That is a sligtly broken starter there, yes.
OP benjamin247: Check the number stamped into the starter, look it up, see if you have something ordinary or a rare number suitable for an H/O.
This is what a no-AC car has on the engine side of the firewall, it's about 12x24"
evans_78
March 13th, 2015 08:28 AM
67442nut
May 18th, 2011 09:34 PM
veltboy618
October 23rd, 2010 08:53 AM
sszewczuk
May 6th, 2010 04:01 PM
LIMEGREEN71
November 25th, 2009 05:30 AM
Quick Reply: Need help identifying these part
