Need help identifying these part
Old Apr 6, 2016 | 01:51 PM
benjamin247's Avatar
Hello,
I need help identifying these parts. The previous owner gave them to me and said he planned on putting in AC and these are some of the parts for it.
Old Apr 6, 2016 | 02:06 PM
Rustbucket2's Avatar
Ok, first one is ac/heater box, goes on outside firewall. second picture is starter, bolts to bottom side of engine and turns engine over to start car.
Old Apr 6, 2016 | 03:52 PM
cool...thank you!
Old Apr 7, 2016 | 10:19 AM
AzMotorhead's Avatar
Benjamin427 the First part you have circled is the underhood"suitcase" for the AC system. In that case is the evaporator. The big valve that comes out of the top is the POA or Throttle suctioning valve. The valve on the bottom line is the expansion valve, Both of those parts are going to be GM A body specific.
You need to know if your car was originally equipped with AC for the suitcase to fit to the firewall. Sure it may physically fit on the firewall, but the hole cutout in the firewall is different from an AC to NON Ac car
Old Apr 7, 2016 | 10:36 AM
Is there a way for me to tell if my car is originally an AC or NONAC car?
Old Apr 7, 2016 | 10:38 AM
Well, is the control panel on the dash for heat only or for heat and A/C?
Old Apr 7, 2016 | 11:02 AM
Post a picture of your firewall ,passenger side. We'll be able to tell you
Old Apr 7, 2016 | 11:05 AM
Looks like in your first picture. There's a AC compressor in the box, also a alternator bracket. Chances are you have a non AC car and the PO was collecting parts thinking it would be a easy swap over.
Bolting on parts is easy. Cutting and patching the firewall sux
Old Apr 7, 2016 | 12:06 PM
Octania's Avatar
The firewall hole to mate the AC evaporator shown is substantially larger than the oh 8x10" hole covered by oh 12x24 plenum seen on heater-only cars.
Rustbucket, congrats on the restraint there. Just the facts. That is a sligtly broken starter there, yes.
OP benjamin247: Check the number stamped into the starter, look it up, see if you have something ordinary or a rare number suitable for an H/O.
This is what a no-AC car has on the engine side of the firewall, it's about 12x24"
67442nut
Jan 25, 2025 12:44 PM
evans_78
Mar 13, 2015 08:28 AM
veltboy618
Oct 23, 2010 08:53 AM
sszewczuk
May 6, 2010 04:01 PM
LIMEGREEN71
Nov 25, 2009 05:30 AM
