Mufflers for Factory 2 1/4" Exhaust
Dynomax used to make a 17561 muffler, that was a 20" x 9.75" x 4.5" body which was as close to a perfect muffler for stock systems. Unfortunately they discontinued this 2 1/4" offset/offset muffler. Does anyone have an alternate brand? I don't like flowmasters, so they wont be a candidate....
Thanks in advance...
What about Walker's 17843. It's pretty close to the dimensions you listed.
http://catalog.walkerexhaust.com/cat...dStatus=ACTIVE
Or maybe this would work: http://www.summitracing.com/parts/imo-cm20/overview/
Here's a .pdf of all the IMCO dimensions so you can match one up to your needs
http://www.imcoweb.com/am_cms_media/...articmwc11.pdf
That 17561 part number shows up as a Dynomax Ultra flow with a 20" case but it has a center inlet, not offset. Maybe they reused the old part number for a new part, i dunno. Otherwise, that part seems to still be good but not with the offset inlet. Part number 17226 is an Ultraflow with offset both in and out but with a case length of 14".
http://www.summitracing.com/parts/wlk-17561
Gotta read the fine print (considering that the photo is of a THRUSH muffler):
"Image is a representation of this item.
Actual item may vary."
This site appears to have the correct photo:
http://autoplicity.com/products/4274...FQWk4AodhFcAQQ
The 17561 is the correct p/n for offset / offset 2-1/4. It's in the Dynomax catalog. I think what I'm going to wind up doing is using a 2.5" Dynomax welded stainless p/n 17560, and adapt the 2-1/2 to 2-1/4. The 17560 has a 20" body/shell and is 25" overall. If I use a 2-1/2" ID on the muffle to a 2-1/4 OD adapter It wont be too noticeable if it's made short enough.
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
