I've seen this info. before. please help
Old Apr 22, 2009 | 05:54 PM
IDAS 69's Avatar
I get to put my car on lift soon. where do I find ALL numbers to verify it as all original. I think it is but want to make sure. carb,vin,frame etc.... Yhak you, Eddie
Old Apr 22, 2009 | 07:34 PM
derek nesdoly's Avatar
olds..older..oldest
I got most of that info on this site's WIKI...carb,intakes.block,heads,trans.....O.K. some from Joe P., Derek
Old Apr 23, 2009 | 06:54 AM
wmachine's Avatar
Trying to remember member
This will all depend on what *exactly* what you mean. By "original", that literally means what actually came on your car from the factory.
Being a '69, there will be a VIN derivative stamped on the block and the transmission. Those are the only things that can truly be thus verified as being original. Other components can be checked to see if they are "correct", but can not be proven to be original. Same basically with date codes.
This is the reality of what the vague term "numbers matching" means for Oldsmobiles.
oldspackrat
Dec 31, 2014 08:26 AM
PSOldsguy
Ninety-Eight
Jul 5, 2012 04:52 AM
theoldsrocket
Jan 9, 2011 08:26 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
DAN76
Jan 2, 2009 06:37 AM
