Interchangeable Rear End
Old Apr 8, 2009 | 04:12 PM
captn442's Avatar
Had a question for you guy's....Will a 67 Malibu SS rear end fit a 71 442. Meaning bolt right in with no modifications....rims....drive shaft....parking brake cable....
Old Apr 8, 2009 | 05:23 PM
Kennybill's Avatar
yes. It might be a 10 bolt 8.2 or maybe the stronger corporate 12-bolt (non Olds)
Old Apr 8, 2009 | 05:31 PM
csstrux's Avatar
I thought the spring perches were different and the track was a tic wider on the 64/67 I take it this is inaccurate?
Old Apr 8, 2009 | 07:11 PM
The 64-67 axles are actually slightly narrower. The spring perches MAY be different. Some 64-67 cars used flat perches with bolt-on retainer plates. Some used the raised spring mounts like the 68-72 cars. You need to use the springs that match the axle housing.
350TurBRO
Sep 12, 2014 11:52 AM
Flye
Brakes/Hydraulic Systems
Jul 23, 2009 09:24 AM
plasma98
Apr 20, 2007 12:06 PM
83olds88
Mar 14, 2007 12:09 PM
Edveen
Nov 6, 2006 09:53 AM
