Rear Drum - Interchangeable? aftermarket?
Old Jul 23, 2009 | 07:20 AM
Flye's Avatar
Got my rear drums to be turned. On the chance they call and say they are too thin to turn....
Are all the GM a-body cars interchangeable? These are not 'finned', they just round and have larger rings running around them (for lack of a better term).
Or should I just pick up a set of 'aftermarket' drums and be done with it.
Car is a 67 442, but has a 71 Olds rear end, so I'm not concerned at this point on super originality on things like this. Just need good quality, no headaches.
Thanks,
Old Jul 23, 2009 | 08:36 AM
Run to Rund's Avatar
They interchange if the brakes are the same size. Vista Cruisers were wider, for example. A nice weight savings (about 5 lb. each) can come from using the aluminum drums from late 70s to 80s Cutlasses etc.
Old Jul 23, 2009 | 09:24 AM
The S-10 pickups also use the same 9.5 x 2" drums with the same 4.75" bolt circle.
matviar
Oct 22, 2014 11:12 PM
dads72
Brakes/Hydraulic Systems
Aug 31, 2014 07:54 AM
455Olds
Dec 8, 2013 08:16 PM
Oldssupreme
Jan 29, 2013 07:03 PM
1carsick
23
Oct 2, 2012 05:50 PM
