How to make my 455 engine faster
Old July 4th, 2018, 04:07 PM
Gbull89's Avatar
I would like to know what carburetor I need for my 455 engine along with which high rise intake and headers to get.
Gbull89 is offline
Old July 4th, 2018, 06:57 PM
72 Olds CS
RetroRanger's Avatar
Many people like the qjet carb works from stock to modified engines, I have one on my car I'm happy with. I had an edlebrock before and it was fine but the qjet feels more responsive.
The performer rpm is a good intake but watch your hood clearance ARH makes some nice headers but they are spensive.
Is your engine stock? If it's modified let us know some specs
RetroRanger is offline
Old July 4th, 2018, 07:18 PM
Gbull89's Avatar
thanks yes its stock
Gbull89 is offline
Old July 5th, 2018, 07:15 AM
72 Olds CS
Stock engine I would use the qjet, edlebrock performer, and any long tube header.
A cam would bump up hp and torque some, a performance rear gear could help out too.
Old July 5th, 2018, 07:20 AM
What year 455? What heads? What valve sizes? What cam? What rear axle ratio? What vehicle? What intended use and RPM range?
joe_padavano is offline
Old July 6th, 2018, 07:34 AM
Tedd Thompson's Avatar
Faster or quicker, there is a difference. More info is needed as was asked above..... Tedd
Tedd Thompson is offline
Old August 6th, 2018, 06:08 PM
billrob71's Avatar
If you find a person who knows what there doing ,a qjet carb can perform very well
billrob71 is offline
Old August 7th, 2018, 12:02 AM
Gary M's Avatar
Answer as many questions Joe asked and you'll be much closer to the answers you need
heads have a letter on them. Driver side front, look for head # there, just above the water pump there are some numbers for the block that may help, is there an EGR valve on the intake? Year and model Oldsmobile your inquiring about, try to get the gear ratio if you can. If not we can help you figure it out.
Gary M is offline
Odmark
March 2nd, 2020 09:15 AM
Odmark
March 8th, 2013 09:54 AM
Jannebill
January 25th, 2013 12:56 PM
scott1256
March 28th, 2012 09:00 PM
oldzy
March 3rd, 2010 02:04 PM
Quick Reply: How to make my 455 engine faster
