Help ID rear gears
Old Aug 5, 2016 | 10:27 AM
My2nd 69 442's Avatar
Help ID rear gears
I'm hoping someone can identify these numbers of my rear diff gear. The code on the axle is S7. on my 69 442
Old Aug 5, 2016 | 11:50 AM
don71's Avatar
same but different
If you divide 13 into 42 you get 3.23 If its a posi carrier, it should be #671.
It looks factory to me, but I'm not expert.
Old Aug 5, 2016 | 12:24 PM
rcorrigan5's Avatar
Randy C.
And, of course, S7 is the code for a 3.23:1 anti-spin differential with disc brakes.
Randy C.
Old Aug 5, 2016 | 12:53 PM
Thanks guys.. That's what it was advertised to be. I had no idea that the 1st set of numbers would tell me the ratio.
I'm learning more everyday,and that isn't easy for this old fart.
Old Aug 5, 2016 | 01:04 PM
don71's Avatar
same but different
I hear you Jerry, as long as we are learning more than we are forgetting, we're doing OK.
Also, if you care to know this axle has 28 splines on the shafts.
Old Aug 5, 2016 | 01:28 PM
Once again Thanks Don and Randy. By the black marks left on the road It is for sure anti-spin and it does have front Disc brakes.
monzaz
Jan 4, 2017 07:35 PM
86GutlessCutlass
May 13, 2016 09:14 AM
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
monzaz
May 29, 2010 08:46 PM
