Gas tank sender wire (brown) how does it route? '68 442
Old March 25th, 2017, 03:07 PM
shamusj's Avatar
Hi guys- after years of using my 442 as a crap holder in the garage I finally cleared a path and started doing a little work.
My gas tank has been out for years- when I removed it I cut the brown lead about a foot from the sending unit. For the life of me I can not find the wire this connects to - I'm curious if anyone knows the path this brown wire takes from sending unit - does it go up into the trunk and then to the fuel gauge or does it go under the car. Sorry for the dump question- I must have messed with the other end of the wire years ago.
Also- the gas tank- I have the standard 442 two line system- both connect to the sending unit and follow hard lines to the front of car. There are two additional tubes at the corner of the tank....Are these vents? Is there a fitting that goes on there?
I should have taken better notes when I pulled it all apart.
Any help appreciated. I'm gonna make some progress on this pile in 2017.
Thanks,
Mike
shamusj is offline
Old March 25th, 2017, 03:15 PM
The brown wire is routed above the gas tank towards the filler neck/license plate area and goes into the trunk through a rubber grommet above the filler neck. Just inside the trunk it has a connector to the harness that runs along the left rear edge of the trunk.
Fun71 is offline
Old March 25th, 2017, 03:41 PM
tomhartrides's Avatar
Fun71, I agree.
tomhartrides is offline
Old March 25th, 2017, 06:06 PM
shamusj's Avatar
Thank you gentlemen - I spent all my time looking under the car....brown lead was in the trunk....just like you said it would be.
shamusj is offline
Old March 26th, 2017, 06:02 AM
tdhill01's Avatar
Originally Posted by shamusj
...Also- the gas tank- I have the standard 442 two line system- both connect to the sending unit and follow hard lines to the front of car. There are two additional tubes at the corner of the tank....Are these vents? Is there a fitting that goes on there?
Thanks,
Mike
Mike, at the corner of the tank there should be two hoses connecting the tank to a plastic tube, inside this tube is a sponge to catch any fuel from coming out - this a vent for the tank. I just replaced my tank, lines and tube.
tdhill01 is offline
Old March 26th, 2017, 10:01 AM
shamusj's Avatar
Thanks Tom- that's exactly what I'm missing. Looks like a 1960's approach to pollution control!
Looks like I've dug myself another hole- a simple gas tank installation turned into full rear brake rebuild, axle bearings, seals, shocks and universal joints. I'm giving myself two weeks to finish this and move on to the front - test firing motor, brake lines (pain in ***) etc.
shamusj is offline
jaybone
April 15th, 2015 06:52 PM
n_holman
Ninety-Eight
November 19th, 2013 07:28 AM
Smitty's72
January 23rd, 2013 09:20 PM
Flye
September 27th, 2009 12:42 PM
dhoff
June 8th, 2009 03:49 AM
Quick Reply: Gas tank sender wire (brown) how does it route? '68 442
